LS2 intake swap
i have a 07 gxp and getting parts to do a LS2 intake swap. i know i need the intake and throttle. do i need the fuel rail and injectors? or can i use LS4? what is the flow rate on LS2 injectors? i plan on delete the DOD parts. what other parts will i need?
You can used LS4 injectors, but will need injector spacers. Available from eBay.
You can use LS2 injectors w/o needing any spacers - just need to tune for them.
LS4 and LS2 injectors used the same connector end.
The 90mm throttle bodies come in two styles - silver blade and brass blade and they suposedly open opposite of each other. The one I installed was the silver blade (LS2/LS7 version).
