GXP Rear speaker help
Old Mar 28, 2014 | 03:32 PM
Ackbar00's Avatar
Question GXP Rear speaker help
One of my rear speakers is blown and I was just going to throw another set of speakers in there. Mine has the Monsoon system and was wondering if they made speaker adapters. I am having trouble finding any.
Here is the plug:
And just to make sure, its a 6 x 9 right?
EDIT: Ended up just buying a replacement speaker. Found it on amazon new for like 55$ shipped.
Old Mar 28, 2014 | 04:03 PM
lVloses's Avatar
Just cut the plug off and solder the wires on to the new speakers. And yes, they're 6x9.
Old Mar 28, 2014 | 04:22 PM
blkchevyz's Avatar
make sure you get the correct ohm speakers.
i think you need something like 4 ohm
Old Mar 28, 2014 | 09:12 PM
08 pimpala ss's Avatar
There is two sets of wires there one set is a low pass for the sub part of the 6x9 and the other is highpass you will have to use the high pass if you want it to sound good at all heres a tech sheet on what the wire colors are
2008 Pontiac Grand Prix DirectWire 2.0 Vehicle Information
Audio
Item Wire Color Polarity Wire Location
Radio 12V orange + radio, gray 24 pin plug, pin B1
Radio Ground black/white - radio, gray 24 pin plug, pin A12
Radio Ignition (Class 2 Serial Data)
Radio Illumination gray (dimmer) + radio, gray 24 pin plug, pin B4
Factory Amp Turn-on (same as power antenna)
Power Antenna purple + radio, gray 24 pin plug, pin B3
Left Front Speaker (+/-) tan - gray +,- radio, gray 24 pin plug, pins A8 - A9
On models with amplifier, the speaker wires are tan - gray (woofer); black - yellow (tweeter) at the amplifier under rear deck, 16 pin plug (C2), pins 15 - 16; 1 - 2.
Right Front Speaker (+/-) lt. green - dk. green +,- radio, gray 24 pin plug, pins B11 - B10
On models with amplifier, the speaker wires are lt. green - dk. green (woofer); lt. green - purple (tweeter) at the amplifier under rear deck, 16 pin plug (C2), pins 13 - 14; 3 - 4.
Left Rear Speaker (+/-) brown - yellow +,- radio, gray 24 pin plug, pins B8 - B9
On models with amplifier, the speaker wires are brown - yellow at the amplifier under rear deck, 16 pin plug (C2), pins 6 - 5.
Right Rear Speaker (+/-) dk. blue - lt. blue +,- radio, gray 24 pin plug, pins A11 - A10
On models with amplifier, the speaker wires are dk. blue - lt. blue at the amplifier under rear deck, 16 pin plug (C2), pins 8 - 7.
Center Channel (+/-) yellow - lt. blue +,- amplifier under rear deck, 8 pin plug, pins 3 - 4
Subwoofer (+/-) dk. blue/white - lt. green/black +,- amplifier under rear deck, 8 pin plug, pins 8 - 7
Aux. Audio Input Left (+/-) N/A
Aux. Audio Input Right (+/-) N/A
RSE Video (+/-) N/A
RSE Audio Left (+/-) N/A
RSE Audio Right (+/-) N/A
Satellite Radio 12 Volts orange + Sat Radio in trunk L side, blk 16 pin plug, pin 16
Satellite Radio Ground black/white - Sat Radio in trunk L side, blk 16 pin plug, pin 9
Satellite Radio Ignition (Class 2 Serial Data)
Satellite Radio Antenna (coaxial cable)
Satellite Audio Left (+/-) brown/white - black/white +,- Satellite Radio, black 16 pin plug, pins 2 - 10
Satellite Audio Right (+/-) dk. green/white - black/white +,- Satellite Radio, black 16 pin plug, pins 3 - 10
