Anyone using Dot 3 or 4 syn. brake fluid?
Old Apr 27, 2014 | 08:47 PM
need4z's Avatar
Default Anyone using Dot 3 or 4 syn. brake fluid?
I went to DOT 4 prestone synthetic on my Z06. A lot of guys did. I dont see why. Dot 4 is just one heat level higher. Better anti foaming and takes the heat better. Less fade. Or even DOT 3 synthetic. Did a search. I guess no one does brakes. My inner pads which always wear first are down to last 1/8" of an inch. Getting occasional squeal. Gonna get ZZP extended ss lines. Do I need extended on the rears as well? New Raybestos Advanced Technology rotors. They look factory. 13.2" diameter. High quality for the money. Used them tracking my Z06. So I swear by them. Couldn't warp them if I tried even repeated hard braking from 150-160 mph. I hate semi metallic pads and ceramic pads fade. I plan on more bite and performance. I'm a fairly high modder,mostly performance improvements. So any answers are appreciated. Hawk HPS street pads. I dont mind the dust and wiping my wheels.. but the pads stop like crazy nuts. Starting to feel more comfy playin' with this car as I wrench on it.
Derek
Old Apr 28, 2014 | 04:10 PM
need4z's Avatar
Figured 91Parkave would have something for me. At least on the ss brake line lengths!
lol
Derek
Old Apr 28, 2014 | 04:40 PM
91parkave's Avatar
Moderator
lol
Derek
I got sidetracked replying yesterday lol, too many tabs open. Not sure about the rear but extends will work fine. Better to err on the side of more in the regard.
Factory rotors for gxps are 12.7 similar to C5 rotors just a diffrnt bolt pattern.
The squel I've come to find out happens when brake dust cakes in the cross drilled holes
Just use a center punch or small screwdriver
Old Apr 28, 2014 | 06:12 PM
need4z's Avatar
Thanks man, but my holes are perfectly clean. Inside and out. Took off a front wheel with a zenon trouble light. Cant find brake dust anywhere. I washed my brakes inside and out with a pressure The squeal is at low speed and only occasionally. I know the sound and its just the start of the pads starting to go. I know I got a couple months on em anyway. Yeah I don't have anything like that in my rotor holes. lol The inner pad squealer tab is super close to touching the rotor. So you mean just to on the safe side get extended SS brake lines front and rear? My Z06 rear ones were a little long. I juts zip tied them to the frame so they were secure. Shoot me another response pal to my comments. I know you wanna! Please Whats your take on brake fluid? I will do syn Dot3 or Dot 4. Shouldn't hurt. Worked fine on the Z06 with a similar brake system.
Yeah the raybestos Advanced Technology rotors are identical and made for the GXP just 1/2" bigger diameter. Hey 1/2" is half an inch!! LOL
:Cheers:
Derek
Old Apr 29, 2014 | 12:11 AM
91parkave's Avatar
Moderator
:Cheers:
Derek
Dot 4 will do great just make sure you get all that old dot 3 **** out as much as possible.
I'm not seeing these rotors you refer to online anywhere? All I see on rockauto is 12.7 and yea extended for the fronts for the rears like I said unsure of. However you cant go wrong with long lol.
Old Apr 29, 2014 | 01:24 PM
need4z's Avatar
I figured so. Here's a link from Amazon for the rotors. Thanks again bud! Oh no all the old fluid will be 100% flushed. I ain't no rookie except with these cars. lol
Amazon.com: Raybestos 580381 Advanced Technology Disc Brake Rotor: Automotive Amazon.com: Raybestos 580381 Advanced Technology Disc Brake Rotor: Automotive
Old Apr 29, 2014 | 02:15 PM
91parkave's Avatar
Moderator
thanks for the link That's a great deal you found there.
I'm just trying to lose rotational mass. Or else I'd be all over these
Old Apr 29, 2014 | 08:58 PM
need4z's Avatar
I understand your point. Still cast iron, gets very $$$$$ when you want materials other than cast iron on your brakes..buy yeah they are a hell of a rotor. My ole Z proved em. GXP childs play! LOL
My good friend is a delco rep, he recommemded those rotors for my Z06. I warped the factory ones doing some very spirited driving. These I put 7K miles on zero issues. Could be the pads, DOT 4 syn. fluid helped as well, all together. My buddy saw me brakes on a curve , he saw them glow red! Cooled off a good as new. I still call these budget but compared to factory they are economy exotic carbon ceramic rotors!Well beyond what I need for this car. LMAO
Old Apr 29, 2014 | 09:20 PM
91parkave's Avatar
Moderator
I hear u...hey if you want more out of it you can always do the CTS up grade 4 piston brembos 14" gt500 rotors
Old Apr 29, 2014 | 09:57 PM
need4z's Avatar
Yeah but I think I will be good with the combo I'm gonna put together. Hey when do you know when you need new struts? i noticed our struts are bery bery special. lol.. Sorry for the typos before.
Old Apr 29, 2014 | 11:32 PM
91parkave's Avatar
Moderator
The only way to really know is to take it off and check for leaks and obvious easy compression of the piston independent of the spring.
Old Apr 30, 2014 | 02:58 AM
need4z's Avatar
Yeah I also read a much rougher ride than usual. Mine are all yellow. Probably Munroe. I know these ride a little firmer than a GP GT. Our struts are exclusive to the GXP or maybe the lS4 cars. I dunno. Congrats man on your 1000th post!!
Derek
