Hud
Old May 15, 2014 | 06:47 PM
eddie_gxp's Avatar
Default Hud
does anyone know how the heads up display works?
just one day mine stopped working
im thinking maybe the blub burnt out im not too sure
hope someone can help me out
thanks
Old May 16, 2014 | 06:49 AM
Haulin_Ls4_GxP's Avatar
Read this
http://www.atthetipwebs.com/technologyinstructions/hud.htm
Old May 21, 2014 | 12:25 PM
Dom87SS's Avatar
mine stopped this week and i found the broken spring hold, now I gotta fix that
Old May 25, 2014 | 10:47 PM
ryanisl33t's Avatar
Originally Posted by Haulin_Ls4_GxP
This.
Old May 26, 2014 | 01:29 PM
dezldave961's Avatar
Did the repair yesterday, and glad to have the HUD back after 3-4 months without it.
Took a slightly different approach to re-building the spring loop, though, just as an experiment. I looked at the cut groove and decided to try applying something more structural than the same plastic getting another hole.
Result was finding a cotter pin that small to set in about the same location (really wanted a bushing, but didn't want to make a store run). It wound up setting in there nicely, and held in place with just one hole made for a "tiny" zip-tie out of the way of any functions.
Works normally, and even has a secondary catch with that leg, if it wears through the 1st layer of metal (although spring would probably wear out 1st). Also still leaves the ability to do the write-up's version with a hole, if I want to change it later. I'd much rather put a thin plate on that front face, with a hole, instead, but I may never need to do that.
