Next Go Fast Mods
Old May 29, 2014 | 11:03 PM
gagt3100's Avatar
Default Next Go Fast Mods
What should I do next for my car. Currently I have 150* of nitrous and a TEP trans and other bolt ons. I don't want to go turbo thats too much $$$. Intake? Lifters? Springs? cam? Whats the next mod that gives the most bang for the buck
Old May 29, 2014 | 11:24 PM
08 pimpala ss's Avatar
ls6 intake!!!!! and throttle body is a good place to start
Old May 29, 2014 | 11:27 PM
gagt3100's Avatar
would you recommend your set up? LS6 with a ls1 tb?
Old May 30, 2014 | 09:23 AM
91parkave's Avatar
Moderator
Your options are wide open. Ls2 w/ls2 TB .,.ls1/6 with their tb . theres no Dyno back to back so we will never know.
For power though I'd be thinking about a plate or direct port kit
Old May 30, 2014 | 12:04 PM
gagt3100's Avatar
they dont make a plate sadly and there is a company that will make a bar set up for spray. I thought LS1 was Cable?
Old May 30, 2014 | 03:29 PM
fieroguru's Avatar
They do for the LS2 throttle body!
Old May 30, 2014 | 06:28 PM
91parkave's Avatar
Moderator
im reffering to when you do a intake swap, Plates are supported. I had my nozzle mounted in my throttle body spacer for a while hit pretty hard but was not 100% on getting the shot to all cylinders, I moved the nozzlle back to air intake for now. I would like to go plate, But my I have pretty much everything i need to go rear mount turbo now, so im making that happen
Old May 31, 2014 | 12:13 AM
Certin years ls1s are cable, its the same tb as ls6 and yes i would recommend my setup u will need hp tuners or a good tuner to make her run with it thow
Old Jun 2, 2014 | 05:59 AM
Killerb's Avatar
It's make things hard to judge add ons, only because no one has any before and after dyno numbers. Headers alone don't warrant a wise investment for a stock ls4, Maybe 5-10 hp for 500-700 bucks is just sadd.
Old Jun 2, 2014 | 10:51 PM
ImpSS07's Avatar
I've got most of what you need for the intake swap if you're interested.
Untouched LS6intake
Brian 396's TB adapter(this allows your stock tb to fit on the LS6intake)
Katech Racing Valley cover/w Katech Racing modded OPSU
PM me if you're interested. PS- its not a cheap setup
