ls6 intake swap MAP sensor question
Old May 30, 2014 | 07:12 PM
2008impalaguy's Avatar
Default ls6 intake swap MAP sensor question
ok i get where you screw on the back of the ls6 intake the new MAP sensor, and u have to buy a map extension wire, but where does the other end plug into( not the alternator side), the other side, where does it plug in at.
Old May 30, 2014 | 07:15 PM
lVloses's Avatar
If you have an 07+ car you can't use an extension. You just have to stretch the wires and it should just barely work.
Old May 30, 2014 | 07:19 PM
ok, i have an 08, so i just use the stock MAP,relocate it to the back, and plug it in like that. cuz in the in the ls1/6 swap sticky pics, it looks like he replaced the ls4 map, with a ls1 map.
Old May 30, 2014 | 07:57 PM
91parkave's Avatar
Moderator
You can use your stock map no matter what year if you peel back the tape. Its better than buying a harness
Old May 30, 2014 | 08:47 PM
awesome guys, thanks for the replies.
