Cruise Control??
Old Jun 22, 2014 | 06:37 PM
roadrash187's Avatar
Default Cruise Control??
I cant get my cruise control to turn on. I had a code that I had a bad brake pressure switch. Replaced that and still have nothing. Havent had a chance to look to see if the third brake light was out. Is there a relay or fuse that I could be missing? Kind of at a loss right now.
Old Jun 23, 2014 | 06:11 AM
Killerb's Avatar
You still might have a switch problem. With a modis ultra hooked up, I could see the calibration was off on mine. It was reading negative numbers 'thinking the car was braking' and not allowing the cruise to come on.
Old Jun 23, 2014 | 10:39 AM
91parkave's Avatar
Moderator
There's a 2 amp fuzse in the passenger side fuse panel also try turning off traction control
Old Jun 24, 2014 | 10:25 PM
I think this could be the problem. I had to hardwire the brake wire for the remote start direct, because it would keep shutting off.
