Some decent track times
Old Aug 30, 2014 | 06:30 PM
08 pimpala ss's Avatar
Default Some decent track times
For the first time on boost and not fully tuned still holding back timing due to a problem with the meth injection causing miss fires due to ls6 intake we think. so i went to the track last night and made 3 passes the first two she ran great and the 3rd it started missin so i let off at the end I am still very happy to see where im at low 12s and shitty 60ft times im
Heres a video excuse the shitty camera man
Old Aug 31, 2014 | 01:34 PM
2008impalaguy's Avatar
awesome times man, getting those 60fts down alone will improve a lot, then final tune and that girl will get out
Old Aug 31, 2014 | 02:45 PM
supercatxr7's Avatar
Good job! Getting some sticky tires on the front and preventing the back end from squatting on launch will help those ET's and 60 foot time. What is the issue with the meth injection and how many lbs of boost are you seeing?
Old Aug 31, 2014 | 03:44 PM
I have been going back and fourth with kevin i keep having misfires on 2&6 he thought it was my accel coils so i went to stock ones then he didn't like the the msd wires he supplied then it was re-gap plugs and the problem did not go away so i tried turning off the alki by pulling the fuse and the misfires went away so then i shaved the tb adapter down where the nozzle is to make more flush and now its only #6 with a problem so im waiting on kevin to tell me where i should move it to and im seeing right around 11psi with the cut out open
Any help or ideas would be awesome thanks
Old Sep 1, 2014 | 08:51 PM
What plugs? I've been using ngk br7ef gapped right out of the box at around .025. My intake set up is different though as I have no MAF and my meth injection nozzle is located farther upstream in intake tube due to that. My car has a speed density tune. I agree with using stock coils over the accels. I have msd wires on the back side as we'll with no issue. When it misfires is it only under wot or part throttle too when in boost?
Old Sep 1, 2014 | 09:18 PM
Only at wot kevin was logged in to my computer the other day when i was making a pass and he said it started as i was letting off right around 80% but i did it the other night and if the cutout is closed its fine im just out of things to try other moving the meth
