gear ratio hp tuner
Old Sep 3, 2014 | 07:59 PM
Sint3k's Avatar
Default gear ratio hp tuner
Anyone have any information on how to change the pcm to adjust for different final ratio on my new transmission? I'll be using hp tuner software, thanks
Old Sep 3, 2014 | 08:31 PM
08 pimpala ss's Avatar
What gear ratio did u go with?
Its super easy click on speedo and its right there
Old Sep 4, 2014 | 08:37 AM
Sint3k's Avatar
My overall ratio will be 3.11:1 , That was the only chain that was available. I could of gotten a 2.93 but wanted better acceleration. I can handle wheel spin with the throttle input. Thanks , i've not actually received the software yet , just trying to get a jump on things. Thanks as usual 08 pimpala ss
Old Sep 4, 2014 | 09:28 PM
x11 nut's Avatar
Hey man, you sure on the 3.11:1 ?? Doesn't ping as a standard ratio..
Old Sep 4, 2014 | 10:14 PM
91parkave's Avatar
Moderator
2:93, 3:29, or 3:69
Old Sep 7, 2014 | 11:56 PM
Sint3k's Avatar
I'm positive , and its not a standard ratio , its a GM racing chain that is making that final ratio with
GM Racing 1" chain set is a rare combination that gives you 36 drive / 34 driven (36/34 = 1.059) so 3.29/1.059 = 3.11:1 which is my new overall gear ratio
Old Sep 8, 2014 | 12:55 AM
91parkave's Avatar
Moderator
You didn't get the inputshaft to go with it?
Old Sep 8, 2014 | 01:10 AM
Sint3k's Avatar
Yes , i got it
its a 300 Maraging steel Input shaft was expensive lol
Old Sep 8, 2014 | 01:15 AM
Sint3k's Avatar
The chain , input shaft , and Torque converter alone where 3000 $
Old Sep 8, 2014 | 07:46 AM
91parkave's Avatar
Moderator
300m is a Zzp item gm offered the aeremet input shaft.
People still shear 300ms at 500wheel if there not careful
Old Sep 8, 2014 | 12:50 PM
Sint3k's Avatar
Yes , but they don't make them anymore and i could not find one. So the 300m will have to do.
