anyone ever test the L76 cam out of a G8 GT in a LS4? wondering if if the combo of that and lifters would be good budget performance and still retain the DoD for those long highway trips.
I know someone swapped in a New Era DoD cam which is meant for the G8 GT. Couldn't speak for the stock cam itself though.
the Ls4 is a 114 cam the G8 116 cam, they both are DoD camshafts and use the exact same lifters. They both have the same lift Dod and non-Dod lobes.
Is it worth the price/trouble to swap? No, You will get more bang for your buck by simply adding 1.8 rockers (note here if you have early Dod/AFM lifters there are newer versions available, your original application PN will be superseded with the newer units thru your GM parts counter)
