remote programming
Old Dec 22, 2014 | 10:11 AM
ssdeuce74's Avatar
Default remote programming
How do I pragram an 07 ss impala remote?
Old Dec 22, 2014 | 11:26 AM
91parkave's Avatar
Moderator
Dealer
Old Dec 22, 2014 | 02:37 PM
05GXPjake's Avatar
It's a "half hour" procedure, so expect to pay $50-65 depending on your dealer's service department
Old Dec 22, 2014 | 06:45 PM
ssdeuce74's Avatar
someone has to know the procedure, I found the relearn in the info screens but it didn't work, I found another way im going to try with the door locks
Old Dec 22, 2014 | 08:20 PM
Sint3k's Avatar
The way your suggesting is without the DIC
However on my monte carlo i have a RElearn Key option thats on the same menu as reset compass and tire pressure monitor
1. Insert Key and turn to ON position so you can access Driver Information Center
2. Press the vehicle information button until PRESS TO RELEARN REMOTE KEY displays
3. Press the set/reset button until REMOTE KEY LEARNING ACTIVE displays
4. Press and hold the lock and unlock buttons on the first keyless remote at the same time for approximatley 15 seconds. A chime will sound indicating that the remote is programmed.
5. To program additional remotes at this time repeat step 3. This vehicle can have a maximum of eight remotes programmed.
6. To exit programming mode turn key off and remove key.
Old Dec 22, 2014 | 08:45 PM
ssdeuce74's Avatar
yeah that's what I did and only one will program one will beep but not work
