Cylinder head flow numbers
Old Mar 22, 2015 | 01:35 PM
Tomkat3012's Avatar
Default Cylinder head flow numbers
Hey everyone I'm in the process of filling out the Pat G cam questioniare and I can't find the stock LS4 cylinder head flow numbers. I ran a search and failed to find it, can someone help me out or at least point me in the right direction?
Old Mar 22, 2015 | 07:59 PM
lVloses's Avatar
We use 243 heads.
Old Mar 22, 2015 | 09:07 PM
Tomkat3012's Avatar
The slip asks for the flow numbers of the heads like .100 .200 and so forth.
Old Mar 22, 2015 | 09:30 PM
91parkave's Avatar
Moderator
He's specd numerous ls4 motors already but anyway here u go
Casting Number 243
Head: 2001 LS6 5.7 Liter Passenger Car
Material: Aluminimum
Part Number:
12564243
Combustion Chamber Volume: 64.45cc
Compression Ratio: 10.5:1
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
Stock Head Flow Numbers
Chamber 64.45 cc-------0.100---0.200--0.300--0.400---0.500---0.550---0.600
Intake 210 cc------------62------126----184----224-----251----256----257
Exhaust 75 cc------------57------108----143----163-----176----180----183
What you need to know:
The LS6 cylinder heads is essentially a tuned-up version of the LS1 head. At 65cc, the combustion chamber is slightly smaller and more efficient than the LS1. The more efficient design shortens burn times and ultimately means less ignition timing advance is required to produce the same power. And because less timing allows more efficient combustion, the Ls6 heads allow the engine to produce more torque. The exhaust port is a unique D-shape that improves flow. LS6 heads are the best choice only when all-out power is needed. Be prepared for a big price tag at the dealer or steep core charge from your head porter.
Old Mar 22, 2015 | 11:15 PM
Tomkat3012's Avatar
Thanks appreciate the info
