Do I need pistons and Rings??
x2
A regular compression tester are also easier to come by and can give you a general idea as well.
how to do a leak down test - YouTube
Mine were when i got the car at 76K.
I'll post some pics of them when i geta chance.
Idk about seafoam man, never used it I'll always use hard parts most of the time. Pistons and rings would be a job for me lol but do able.
On the other hand it'll probably be just fine lol. Run it?
For just tuning with a packaged tune and turning off the DoD/ AFM... you still have to datalog and dial it in.
There are many areas that oil consumption can come from as other posters have mentioned and there are TSB`s for the PCV system/ rear valve cover problem and the DoD for example. there is also the possibility of vacuum leaks... like at the DoD sensor on the brake booster or the inner PCV hose failed (remove it and roll it in your fingers to see if the inner liner is ll cracked)
What it comes down to is a proper diagnosis first.
