Putting everything together this weekend any tips
My problem was the intake lifter on cylinder 1 turned sideways and also scored up the cam pretty good. got the heads cleaned and pressure checked they af good to go also put new valve seals in
What oil were you running anyways with the turbo setup? If you are still on 5w30, I strongly suggest swapping to something like a Rotella 5w40.
Speaking of oil, are you changing the oil pump while you are in there? If you do, verify you are using the correct o-ring on the pick-up tube.
Good luck!
Good luck!
