Tranny issue again
Old Oct 14, 2015 | 09:42 PM
tim4daflow's Avatar
Originally Posted by 91parkave
How are your mounts
Mounts are still good
Old Oct 14, 2015 | 09:55 PM
rottonj's Avatar
Jack it up and see if it does it on the stands also. A cv joint or hub going bad without road pressure might react differently when driven. Not really sure.
Old Oct 22, 2015 | 05:28 PM
heavyft's Avatar
When I had my tranny rebuilt it had a slight shudder on acceleration so the shop put in a new valve body.
Old Nov 3, 2015 | 10:05 AM
tim4daflow's Avatar
The tranny shop took my tranny apart yesterday I broke the chain I had the upgraded 7/8 chain already there is no better chain besides the 1 inch right?
Old Nov 3, 2015 | 10:42 AM
spawne32's Avatar
You broke the chain??? How much power did your car dyno again?
Old Nov 3, 2015 | 11:03 AM
91parkave's Avatar
Moderator
3:69,typically are more unreliable of a gear set. 2.93 being the steongest available 3.29 being the second best
Old Nov 3, 2015 | 11:45 AM
spawne32's Avatar
No one has yet to be able to answer why the chain drive is somehow weaker with different sprockets. IMO its just a matter of statistics, less people use the 3.69's and they are typically higher powered car's so they have a higher failure rate. Doesn't give it more or less strength then the other sets, the drive chain is the same regardless.
Old Nov 3, 2015 | 11:56 AM
tim4daflow's Avatar
I believe they all are the same length the 3.69 just puts more stress on the chain I guess I'll just put another and hope for the best
Old Nov 3, 2015 | 12:02 PM
tim4daflow's Avatar
Old Nov 3, 2015 | 12:50 PM
91parkave's Avatar
Moderator
Simple, think about a bike gearset, 1st gear is tall and big, which if you figure in torsional forces and everything else is more likely to shear and cause loading issues side to side on the chain then let's say the small 7th gear would, as its less material and doesn't have as much ability to fail. Hence Why the super high power cars are on 2.93 or the 3.11 gmr set.
Old Nov 3, 2015 | 02:10 PM
Koren's Avatar
Question, so a rebuild with those chains would be much better obviously, but is there anything needed to support those chains?
Old Nov 3, 2015 | 03:48 PM
  #32
91parkave's Avatar
Moderator
All chains need the matching gear sets that's it for that portion
Old Nov 4, 2015 | 09:39 AM
  #33
superglide9375's Avatar
is the chain stretching and then popping when power is ramped up?is almost like we need a self adjusting tensioner to keep chain taut
Old Nov 5, 2015 | 09:13 AM
  #34
Koren's Avatar
Ahh I see I see.
