07/08 gxp
Old Nov 26, 2015 | 07:29 PM
Sick LS2's Avatar
Default 07/08 gxp
Hey guys so I have done some research and really am not able to locate anything. I have a 07 GXP that I DD with 140k on it and I was able to purchase a 08 GXP that was involved in a wreck. I am having throttle body issues on the DD and was going to swap the TB but found that my 07 is a 8 pin connector and the 08 is a 6 pin connector.
Is there any data on why the change? Would there be a solution?
Thanks
Old Nov 26, 2015 | 07:54 PM
Cocor's Avatar
Pretty sure they used different pcm's, therefore the harness changed.
Old Nov 26, 2015 | 07:58 PM
Sick LS2's Avatar
Really? I wonder why....its the same dam car/engine!!!
Old Nov 26, 2015 | 08:16 PM
Sint3k's Avatar
I'm not entirely sure, i'll do some research later if no one who knows better chimes in, but im almost sure that, you can convert it over to the 6 pin connector by ommiting 2 of the wires, which wires however im not sure. I'll see what i can find
Old Nov 27, 2015 | 12:03 PM
superglide9375's Avatar
i got an ls6 tb with the 8 pin connector that pimpala converted over ill sell it for what i paid-240 shipped
Old Nov 27, 2015 | 12:05 PM
or ill sell harness for 80 shipped
Old Nov 27, 2015 | 05:32 PM
Sick LS2's Avatar
the harness converts it from 8 pin to 6? I already have a TB its the connector that's my issue.
Old Nov 28, 2015 | 12:01 AM
lVloses's Avatar
Thanks
07+ LS4s all use the e67 pcm. But for whatever reason, maybe for legacy's sake, they kept the throttle body a 8pin in 07. All LS4's 08+ use the 6 pin which is the same pinout for all newer LS's. The 8 pin can be converted to a 6 pin by following this:
https://ls1tech.com/forums/ls4-perfo...b-pin-out.html
Old Nov 28, 2015 | 02:00 PM
ok thought u were going other way does your plug have 8 or six the part that your tb goes into on car? i have a harness that has an eight pin connecter for models before 08 which is what i have so i would have had to convert it to 6 pin so i just bought ls3 which plugs right in with 6 pin
Old Nov 28, 2015 | 02:05 PM
can't u put your harness on to the 08 tb?the plug on tb should be same the head is just different with 6 or 8 pin i think i am not sure thou hopefully someone will chime in and set me straight on this
Old Nov 28, 2015 | 06:01 PM
Sick LS2's Avatar
I tried putting the 08 TB on the 07 but the connector wont fit its 2 male ends...
Old Nov 28, 2015 | 06:29 PM
the harness i have is 8 pin that a guy on her repined to fit his 06 imp ss, i think it might work i think the end is double male ill check tomm
Old Nov 28, 2015 | 06:31 PM
its over my buddies house we were fitting it ti ls6 man but i had same problem I'm 6 pin the harness goes to 8 pinn but its too ls6 tb so don't know what the ends are never took it off
Old Nov 28, 2015 | 06:49 PM
i got 2 in my pictures tell me the one u want 75 shipped monday
Old Nov 28, 2015 | 06:59 PM
lVloses's Avatar
Check out that link I posted earlier. Just buy a 6pin connector on eBay for cheap and then solder it in following that link. Will take you 15 minutes.
Old Nov 28, 2015 | 11:28 PM
Sick LS2's Avatar
I checked it out and that's the plan....I was really more curious as to why they changed it and if anyone had any info.....the cars are identical
