Electrical Issue
Any ideas why the battery read zero volts but came back? Is there internal protection on the battery that shuts it down? Also any ideas where to check for a parasitic draw? I found some people saying the factory amplifier for the radio can cause this scenario.
2006 Impala SS
Thanks.
I personally can't think of a reason you'd have a battery read from 0v to suddenly having energy.
It is drawing 1.7 amps with everything off. The problem appears to defiantly be radio related as I pulled the 20a fuse out and draw dropped to less than 0.25 amps and voltage from across the terminals jumped from 12.5 to 12.7 volts. When I put the fuse back in, everything stayed the same until I turned the radio on and off. Once I did that with everything off again, the draw at 1.7 amps and voltage across terminals held at 12.5 for over 20 minutes.
