Error Code P0521
This is just be beginning, ultimately the code is set because
"The ECM detects that the difference between the predicted oil pressure and the actual oil pressure is either less than 47 kPa (6.8 psi) or greater than 50 kPa (7.3 psi)."
SO this can be a wiring issue, this can be a mechanical issue.
Lets get some facts out the way first:
The black wire on the oil sensor is the "Low Reference", This is what the computer uses to determine its baseline for "ground".
The Grey wire is the 5volt reference wire, there should be pretty much exactly 5 volts at this wire with Key On engine off, or key on engine running.
The Tan and white wire is then "Sensor Circuit", 4 volts for high oil pressure, 1 volt for low oil pressure "Roughly" So key on engine off, you'll read its lowest reading, "around 1 volt". Im not sure of its voltage at Idle, which is around 24"low" - 30-40" normal" PSI of oil pressure on an LS4.
So to start off with, the 5 volt "grey" wire needs tested to insure it is getting 5 volts
Next,
we need to make sure the black wire is a ground good ground with nothing causing high resistance. To do this you will need to do a voltage drop test. 1 lead of your DVM should be connected to battery negative, and the other should be connected to this black wire. you should see no more then 100milivolts, preferably way less. Another test for the black wire is to test the ohms reading, connect 1 lead to a GOOD ground, and the other to the black wire of the connector, in this case the connect will need to be unplugged does not matter if the key is in for this test.
Preferably, both test should be done with Key On, Engine running. If you can, report the voltage on the tan and white as to what the idle voltage is, also take note as to wether this voltage is steady or flucating greatly, and what it is flucutating between etc. Another test that can be done is with the connector unplugged, do a voltage test between the tan and white wire, and ground and report what the voltage is. I hope you write all this down and are detailed as to what is what It will help me from having to ask a repeat of questions .What Impala06ss posted previously is also a good idea as this code can very well be mechanical. Do you have a scan tool that can read live data ?
Let me know what you find and I'll try to assist you from there
1,000 RPM 24PSI
2,000 RPM 35PSI
3,000 RPM 38PSI
these are all on the very "Low end" of what is expected at these RPM ranges. Add about 10-15PSI for "normal" pressure. These would be with the engine at operating temp.
I should also mention that the CEL could be on one drive, then the next off. But it is on more than it is off.
