Rotor Scoring getting bad...
I can't see it being a caliper or a slide because it is only a small maybe 5mm thick line or lines, whereas if a pad was not applying correctly it would make sense for a larger area of the rotor surface to be gouged, not just one line in the middle as the case is with the front one.
It might be worth inspecting the pads closely to see if you are having a similar problem.
Don't let your local parts supplier talk you into any $1 packets of caliper lube near the register
either, get this as you will have it for sometime.
