HVAC Fan and heated seats not functioning
I'm going to assume you mean the, "HVAC Fan" and both driver and passenger heated seats would not work. With that said, both of those items are on completely different ," Power and ground circuits". BUT, they both share needing to communicate with the HVAC Control Module to function correctly.
There is a seperate module for the Heated seats, BUT, The hvac module is what ACTUALLY tells the Heated seat module to turn on. SO the likely culprit is the HVAC Module itself,
1 or 3 things has happened or is happening
1:The HVAC Control module some how lost its power feed (Fuse, poor connection, open"Cut" wire)
2:The same as 1, except for a ground wire, minus the fuse of course.
3: The HVAC module glitched or is failing.
