Need Help Picking Out Trans Cooler Kit
http://shop.tripleedgeperformance.co...TC4921-LS4.htm
This other one on eBay uses the same size type and size of cooler, and is way cheaper because it appears to be a more universal kit...was recommended by someone on LS4 Nation on FB...price is $139
http://www.ebay.com/itm/191796678400
So, considering I need 2, as I have 2 LS4s, what am I spending the extra $340 with TEP? Braided hoses, nicer fittings, the cooler end of the line welded on, and that's about it, right? I know the cheaper kit has brackets that may need to be modified to fit my cars properly.
Am I better off with spending the extra on the TEP kit, or should I just stick with the universal eBay kits? Any help is appreciated...I don't know much about transmission coolers, and have never installed one. I work for a Cadillac dealer, and when labor is $30/hr for me, I'll let them do it!!!!
https://www.amazon.com/dp/B00B0OYI9O...I1BYSVL7T11OTU
It has everything you need in the kit to get on the road. It is a VERY tight fit (I removed bumper) and I put spacers on the bottom radiator support bracket to allow it to slide in place. I installed it as a standalone unit.
Temps dropped from 195-205 average, to not getting any hotter than 160. It was an immediate difference.
IMO, yes, that is what you are paying for is the stainless steel pieces, but there is obviously a ton of margin built in.
No one I talked to on LS4 Nation mentioned removing the bumper, but I can easily see where you might need to. Gotta love 30/hr labor as a job perk, either way!
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
