LS4 Accessory Drive & LS3 ??
The LS4 crankshaft is shorter, but it is still recessed bellow the surface of the LS4 balancer - the crankshaft doesn't need to be as short as the LS4's. Worst case, just use a stepped washer to clear a protruding crankshaft.
Belt alignment to the LS4 pulley will require relocating every accessory closer to the timing cover, which can cause more fitment issues in the engine bay.
The LS4 water pump is a wide monstrosity that limits space at the lower portion of the engine for the accessories. It also wont clear a lot of forward facing intakes, and the normal belt path is right through the throttlebody location.
I extensively modified the one in my Fiero to change the location of the hose connections to make room for the low mount alternator and to allow the belt path to go below the water pump.
The LS4 water pump is an amazing structure, just try to make that at home LOL>
I likely don't have the same space issues you have but surely your setup is the narrowest around.
