Intro and questions about the GP GXP
At any rate... assuming it's in great shape front to back... It's a fun car unmodified the GXP anyway forget 320 HP or 330 the extra 25 HP is not going to translate into anything.
Assuming the factory Bilsteins are still good, if I were you, I'd simply invest in front and rear Shock tower braces first. Doing so WILL improve cornering drastically at a super cheap price compared to any other mod you could do at triple the price even.
If anything further for suspension... just buy some CMS lowering springs for the factory Bilsteins because the factory shocks are good and the car will look even better with a slight drop. The factory springs are probably tired now anyway... combine that with like I said the front/rear Strut tower braces and that's the end of your suspension and handling mods... super cheap.
Leave the Engine alone... just wanted to remind you again because I know you're still thinking about that 25 HP. If you really want to do something under the hood then simply change out the soft stock dogbone bushing with a POLY bushing. This you will notice benefits right away! And it's super duper cheap to do.
Put on 275 wide tires of your choice on the front right away... then... when it's time to replace the rear tires... go with a bitter wider than stock maybe a 235.
Don't touch the exhaust with cat back anything it's just a waste of money the car sounds fine stock... if and when the mufflers rust out figure that out then.
Put the rest of your money into the paint... take it to a real shop and do some paint correction and real pro buffing... make the car look good so when people see you they give you good looks instead of showing up with a scratched up car that you have get people to listen to all the mods you did for them to look past the shitty 14 year old neglected paint. Don't drive a scrub.
That's what you should put your money into beyond what I said.... Paint.... again the list is...
1) 275 Front tires
2) CMS lowering Springs
3) Front/Rear Strut Tower Braces
4) Poly Engine Mount
5) Paint Correction and Clear Finish
Make sense?
If anything further for suspension... just buy some CSS lowering springs for the factory Bilsteins because the factory shocks are good and the car will look even better with a slight drop. The factory springs are probably tired now anyway... combine that with like I said the front/rear Strut tower braces and that's the end of your suspension and handling mods... super cheap.
1) 275 Front tires
2) CSS lowering Springs
Make sense?
There are no cheap HP adders to this platform, so consider instead taking comfort in the idea that wider front tires will afford you the ability (on a stock motor) to accelerate more aggressively than normal anyway. Back in 2006 the GXP was quick but a lot of cars (stock) you wouldn't think of are now are quicker than the GXP... so adding power to your GXP in my opinion should either be 1) not at all... or what I did which was... 2) All the ******* way. No third option in my opinion.
Ideally you can learn 10x more 10x quicker if when you go see the 06 car and HOIST IT at a local shop. It would be worth paying a local shop $50 to hoist it for 10 minutes the stuff you will find will give you the dirt you need to beat the guy up on his price and get multiples back of your $50 hoist investment.. but... If when you see the car the Bilsteins exhibit signs of leaking or bouncy ride... then you could opt for a full 4 piece replace using BC race coils which for those that have added them to Grand Prixs talk extremely highly of them. That is an option too that would negate the need for lowering springs which likely cost maybe about 13% of the BC coils anyway.
My advice would be to start reading up, there's about 15 years of information here and if you are asking about shocks for the GXP you need to do some reading.. Start your search with the transmission, if that doesn't scare you away continue on. Good luck with whatever you decide.
