ABS and traction control delete .
Old Dec 22, 2019 | 09:08 AM
Jmay's Avatar
Default ABS and traction control delete .
2006 Chevy impala 5.3. I transplanted everything into a kit car except for the complete brake system. I have two problems I’m trying to solve they could be one in the same . 1) if the ABS module is plugged in and dangling the car will start. If I unplug the ABS module the starter will not engage. Looking for a fix. 2) if I stand on the throttle the engine will stall for a few seconds then kick in. I’m thinking this has something to do with the traction control. Any suggestions will help. Thanks
Old Dec 22, 2019 | 10:52 AM
jayyyw's Avatar
The ABS plug likely has CAN wires running through it and they need to be looped so the car will start without the module.
Old Dec 22, 2019 | 06:15 PM
fieroguru's Avatar
You will also have to zero out all the torque management settings in the tune.
Old Dec 22, 2019 | 07:45 PM
Jmay's Avatar
can you be any more specific? Torque management in the engine or trans and witch ones? I just got my hp tunner and I’m barley finding my way around it. Lol I’m not finding much info on my problem either. Thanks agine for any help you can give me.
