Rear Brake Backing Plate
Old May 19, 2020 | 12:20 AM
corsair231's Avatar
Default Rear Brake Backing Plate
Guys, I know it's going to be a used part only at this point but I'm in need for a rear brake backing plate for the driver's side of a 2005 GXP. Question is do all of the LS4 cars use the same one or is the GXP one GXP specific? I know the Grand Prix 3800 cars are different so no joy there. Just need to know exactly what my options are.
TIA
Old May 21, 2020 | 09:56 AM
rottonj's Avatar
I could be wrong but I think the GXP rotors are different, rear are about 12 inches and fronts are 12.7. I think the other LS4 cars use smaller rotors. I would think the rotor size would determine the backing plate. Post back your findings. Thanks
Old May 28, 2020 | 09:34 PM
corsair231's Avatar
After checking around I think the real difference is the parking brake assembly and not the rotor size. The GXP uses a drum style parking brake which is mounted to the backing plate while I believe the other LS4 cars uses the caliper as the parking brake.
