Grand Prix GXP
replaced O2 sensor twice, to no luck incase first was defective. Replaced harness plug, to no luck. Check power voltage 13v. Ohmed out wires to 6” from pcm… all to no luck at 0.1 ohms on all 3.
what could be causing the p0135 sensor 1 heater malfunction besides the o2 sensor and wiring?
Ohmed out all 3 wires to pcm. 0 ohms, so the other possibility is wire sheathing poor. So yes, found
the wires going through main wire harness are catching magnetic fields.
pulled the wires out of harness, completely entangled, so had to cut and splice back in. Wrapped in electrical tape once over. Good enough to stop the magnetic fields from other wires in harness. Separated alternator power wire and O2 sensor wires into new loom.
going back to loom in the main harness once that arrives.
