Throttle body vacuum line?
The reason I think this might solve the misfire is, the car also had a short to the engine coolant temp sensor and the lifter tick noise got softer when I fixed the short. Hoping that the throttle body position sensor is causing the ignition system to not function properly. After saying all this out loud I am realizing this is a long shot and I will most likely be removing my valve covers today lol. If its a lifter that might be above my you tube mechanic ability. Although my next step would be to go through the coils again to see if I missed something the first time.
Anyone know what the vacuum line that connects directly to the throttle body is called/connect to? What type of hose do I make a new one with? Any vacuum hose?
