Information on LS Engines Here
Old Nov 12, 2005 | 08:36 PM
pdqgp's Avatar
Default Information on LS Engines Here
Came across this tonight. Here's a great link to information on the Gen III LS engines, including the 5.3l LS4.
Happy reading.
http://www.automotiverebuilder.com/ar/eb040538.htm
Old Nov 12, 2005 | 10:34 PM
LS4 GXP's Avatar
Tim, reading through that article, I believe the 5.3 it is referring to is the truck motor. The LS4 is technically a Gen IV, like the LS2/LS7.
Just to add to the info, here are some things that I have come across and collected:
DoD info from GM service manual: http://www.fastfieros.com/tech/DOD5_3.htm
DoD oil path and lifter operations: http://www.fastfieros.com/tech/dod_oil_path.htm
4T65E FWD Transmission Content Changes for Gen 4 V8 (LS4) Application:
- 258mm, RI 15 Torque Converter
- Enhanced Heavy Duty 3.29 Final Drive
- 2.93 Effective Final Drive
- Transmission case for transmission mounted starter
- Net-formed Input Sun Gear
- Ceramic bead Peened Final Drive Sun Gear
- Input/Reaction Carrier Assembly
------ Contour Hardened ReactionInternal Gear
------ Input Carrier & Gear Asm. with lube grooves
------ Shot-peened, Black-oxided Input Carrier Pinions
------ Shot-peened Reaction Carrier Pinions
- Shot-peened Final Drive Sun shanft
- Upgraded Drive sprocket Thrust washers (new for high speed capability)
Camshaft specs:
Camshaft Lobe Lift - Intake - Non Displacement on Demand Cylinders
7.2 mm
0.283 in
Camshaft Lobe Lift - Intake - Displacement on Demand Cylinders
7.33 mm
0.289 in
Camshaft Lobe Lift - Exhaust - Non Displacement on Demand Cylinders
7.2 mm
0.283 in
Camshaft Lobe Lift - Exhaust - Displacement on Demand Cylinders
7.33 mm
0.289 in
Old Nov 20, 2005 | 05:19 PM
Dales396lt4's Avatar
So what is the lift with 1.7 vs 1.75 or 1.80
Old Nov 22, 2005 | 03:56 PM
FastFieros's Avatar
I posted in another thread I found with LS4 vs truck 5.3, but I will recap here also.
New document at http://www.fastfieros.com/tech/vorte..._gen_iv_v8.htm
The truck DoD engine is LH6. Nice engine. I have a brand new one for a Fiero.
Loyde
