Ls4 Dyno Numbers?
Old Apr 12, 2006 | 12:11 PM
N20LS1's Avatar
Question Ls4 Dyno Numbers?
Has anybody dynoed an LS4 cars. I so, what was the fwhp?
Old Apr 12, 2006 | 06:23 PM
oxidizr's Avatar
I have tested a Monte Carlo SS and a Pontiac Grand Prix GXP. Ill post em' up tomorrow.
Old Apr 13, 2006 | 05:24 AM
BigMikeGXP's Avatar
Hopefully graphed from at least 2000 to 6000 rpm?
Old Apr 13, 2006 | 09:12 AM
jdaniels's Avatar
This Monte?
https://ls1tech.com/forums/showpost....28&postcount=7
Old Apr 14, 2006 | 04:07 AM
BigMikeGXP's Avatar
That graph only has about 1000 rpms worth of data on it. Which is descent. Would be nice to see the entire power band though.
Old Apr 15, 2006 | 08:54 AM
oxidizr's Avatar
Unfortunatley, you cant see more than this. Being an automatic it will nto allow you to sustain low rpm at full throttle. It simply downshifts. "Smart" transmissions are no easy to get full powerband numbers without some kind of transmission controller.
Old Apr 17, 2006 | 01:59 AM
BigMikeGXP's Avatar
Tapshift
Old Apr 17, 2006 | 12:57 PM
Richiec77's Avatar
When you dyno, the car needs to be in a 1:1 gear. Hence 3rd gear in an OD auto. What he is trying to say is that it won't hold in 3rd, but downshifts. Most F-body's and Vette's, dont have this problem on the dyno since almost all shops can hook-up something to hold the transmission in gear thru the computer.
Even with tapshift, it still might downshift automatically. (Or did I miss something about that feature in the Pontiac's when I read about it?)
Old Apr 19, 2006 | 12:14 AM
BigMikeGXP's Avatar
3rd gear can be run from 3000 rpm to about 5700~5800 rpms with full throttle.
Old Apr 24, 2006 | 09:13 PM
GXPPOWER's Avatar
the car will not downshift using tapshift. i many a time hit the car and frogot to downshift and watched a car blow by me... untill i downshifted ofcourse i almost miss it alittle... oh wait nm i have a TA now i dont miss it
Old May 26, 2006 | 04:02 PM
dezldave961's Avatar
Lightbulb
The GXP in our local GP club dyno'd 239.0-242.5whp and 316.0-324.3wtq (not correcting for TC flash). These runs went from 2800-6200rpm.
Oddly enough, if you calculate for 20% drivetrain loss on the WHP, you get 303.125hp.
LINK to GXP member profile on MCCGP
Fairly consistent, and impressive as well.
- Dave
Old May 30, 2006 | 08:11 AM
BuffaloSS's Avatar
242 is about what i've seen any time someone has posted dyno numbers. Those torque numbers look similar as well.
