Drop in K&N
Also I ordered a 160* thermostat for a 06 GTO LS2, gonna drain all the Dexcool, flush the engine a couple of times and then install the 160* and some distilled water and a touch of the green stuff and maybe some water wetter or Royal purple stuff and maybe she'll run alittle cooler than she does now.
Any inputs are welcome!
Tate
Not trying to start an argument... but why would you put the green stuff in? Dexcool has a longer life and is designed to be used on these engines. You start having problems when mixing the green and pink together. I know for a fact that when mixed together they start gumming up. And there is no way you would ever get all of the Dexcool out even if you flushed it 10 times.
Also thinking about getting a 160 t-stat. Looking at where it is... its gonna be a bitch to change out. But it will be worth it to not have a friggen oven under the hood.
Has anyone thought of making a fan control switch? Anyone have any access to wiring diagram for the GXPs/SS's?
Tate
