LS4 engine and trans
Old Jan 8, 2007 | 06:25 AM
valvegod's Avatar
Default LS4 engine and trans
Anyone looking for a new take out LS4 engine and trans, with front accessories and starter. no pcm or harnesses.
$2200.00
Shaun (valvegod@aol.com)
248.276.0483
Old Jan 8, 2007 | 07:06 AM
eddiemoney's Avatar
Im confused on what good an LS4 would be without the computer and accessories.
Old Jan 11, 2007 | 06:55 AM
SILVER LS4's Avatar
Default poss info
If I had access to an ls4 sitting around I would probably check it out and see if an ls2 intake will actually fit/work on it mounted backwards (are the rumors true that it's symetrical and all the ports match up). Maybe even check out those lifters and see if they could be replaced by stock ls2 lifters and do away with dod for the sake of limitless cam combos. I would try to answer any other questions you guys had also. Then share the info with the rest of you out there. But I don't have $2200.00 or and ls4 sitting around.
Old Jan 28, 2007 | 10:26 AM
working4toys's Avatar
sounds like a good price anyway
