Strut Tower Braces?
Old Feb 5, 2007 | 03:09 PM
Mgpeagle's Avatar
Default Strut Tower Braces?
Are there any that will fit the front and rear of the GXP? If so, where do you buy them? Thanks in advance.
-Mike
Old Feb 5, 2007 | 03:41 PM
Area47's Avatar
alternator is the problem on the front
rear is just the standard one from any gp from 04+
Old Feb 5, 2007 | 03:56 PM
Mgpeagle's Avatar
Thanks man. I can't believe someone doesn't make brackets to clear that. Seems like it wouldn't cost much... Thanks for replying.
-Mike
Old Feb 5, 2007 | 04:52 PM
Area47's Avatar
-Mike
take the hood off, it will clear all day long.
the problem is the alternator sits too high, when you put the bar on with don's mounts, it pushes against the hood,
this is on the gp, dunno about the monte and imps
Old Feb 5, 2007 | 05:20 PM
BuffaloSS's Avatar
ZZP brackets work for the ImpSS on the front. Donrome's (from clubgp) brackets work for the rear. DOn't know if this helps.
The ZZP front brackets are raised and help to get over the alternator.
