Where's the coolant going?
Old May 15, 2007 | 12:38 PM
BuffaloSS's Avatar
Default Where's the coolant going?
21,000mi - I've got next to nothing in the coolant resivoir when hot, and not much more when cold. Where the hell is it going and should i just top it off or see the dealer and let them do it? I can now hear the coolant swishing through the dash area, so i'm guessing it got some air in the system, too.
Anyone else having this issue?
Old May 15, 2007 | 12:48 PM
06 SS's Avatar
Mine has been steady as a rock since new (10500 on it now), no gurgling, no adding. Check it about every 3 fill-ups.
Old May 15, 2007 | 02:43 PM
06MonteSS's Avatar
LS1Tech Sponsor
I had the same issue Buff... about the same mileage too... I never checked mine when new, so I don't know how much was in there to start with... but I filled mine up when I saw it was way low, and it hasn't gone down at all since...
Told my service tech about it, and he said it was normal for it to "use" some up every 3-6k miles... but he said it shouldn't have been THAT low.
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old May 15, 2007 | 02:51 PM
Mike's 01WS6's Avatar
Mine has read high for a while, then it read low for a while, and now its right on the line again. Check the radiator hoses, heater core hoses, around the heads and thermostat housing, and the floorboard if it is damp if the heater core is leaking, if the head gasket is really bad it will show up in the oil, if you dont find anything take it to the dealer anyhow if you can find time just so there is some documentation if something goes wrong and they try to say that you let it get low and messed it up. Check the coolant temp sensor too, the thread sealant on my cam sensor was crappy and my car was pissing oil pretty soon after I got the car.
Old May 15, 2007 | 04:22 PM
BADDLS1SS's Avatar
Mine had done that when it was new, i changed the thermo and it never did it again after that... some sort of enigma lol
Old May 15, 2007 | 07:19 PM
jabronie78's Avatar
22000 on mine and haven't lost a drop, my powering steering has been low and had to put in a quart of trans fluid.
Old May 15, 2007 | 07:31 PM
Kazmaniac's Avatar
Buff - 27K and dead nuts on the line.
Looks like oil consumption has slowed way down.
Old May 15, 2007 | 08:20 PM
NewYork Art's Avatar
Yea mine is empty,,I think I should get some extra and fill to the line. I only have 2,500 miles
Old May 17, 2007 | 09:51 PM
okie123's Avatar
I had the dreaded where is the antifreeze slowwwllly going phenomenon.
Found my problem when changing the oil tonight. The water pump output hose is leaking somewhere. Guess I'll pull the thing off and give it a good inspection this weekend and replace the clamps at least. Probably the hose too since I dont want to do it twice. What a mess.
Old May 19, 2007 | 10:04 PM
okie123's Avatar
The compression clamp was not on seated properly coming out of the water pump. After 42k it finally leaked enough for me to see it. Next time you change your oil look at the bottom of the U on the hose coming out of the pump. See if its damp or wet.
You will also need long compression clamp pliers to even think about re-adjusting the compression clamp. The top clamp is not leaking but its not on very good either.
Its next to impossible to reach.
Old May 20, 2007 | 11:26 AM
BuffaloSS's Avatar
Will look into that, thanks. She'll be at the dealer before i need to do oil again, though, so i might tell them to do it.
