Tire pressure Track vs Street?
Old May 29, 2007 | 02:00 PM
live2ride's Avatar
Default Tire pressure Track vs Street?
I always hear that the pressure of street tires should be lowered at the track from between 20-25 depending on who is talking, to get the most bite. Yet normal pressure should be in the 30’s.
If lowering the pressure helps bite at the track, wouldn’t it also help on the street? I don’t think I’d like the pressure to be lowered for normal driving due to the drawbacks of rolling resistance and long term heat problems. But if it would work for a little pleasure drive, just a thought.
Any input?
Old May 29, 2007 | 02:13 PM
06MonteSS's Avatar
LS1Tech Sponsor
I know roads aren't as smooth or as debris-free as a track, so by running lower pressure on the street, maybe it could f-up the sidewalls?? as well as getting worse gas mileage...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old May 29, 2007 | 02:31 PM
scarlett's Avatar
I run usually 29 psi on the street and drop it down to 18 psi at the track. For the rear I always leave it at 42 psi
Old May 29, 2007 | 03:24 PM
eddiemoney's Avatar
42 psi . . . holy blowout batman
You will put undue stress and odd wear on your tires if you consistently run low pressure. You will get better traction on a launch, but poor cornering, as your sidewalls won't be as stiff. For street I would never drop under 25psi, track i would consider going a little lower.
Old May 29, 2007 | 03:57 PM
cookba's Avatar
for street i stay around 34-35 in front and 32-33 in rear. this is with KDW tires though
Old May 29, 2007 | 03:58 PM
cookba's Avatar
42 psi...........haha thats what they tell you to keep your tires at when you go to the military sponsored defensive driving classes.
Old May 29, 2007 | 07:21 PM
live2ride's Avatar
I completely understand all the negatives with low pressure, just focusing on straight line traction. With the low sidewall I was trying to figure out what the real benefit might be. Another way of putting it what’s the difference between 22 vs. 30 with regard to straight line traction. I normally run the tires a bit on the high side (35 hot) for less rolling residence but not too hot so as to put the weight and wear towards the center of the tire.
By Brett Foote | 2026-06-04 05:00:17
