Sticky for tuning our cpu
Old Sep 25, 2007 | 06:54 PM
mikeroot2's Avatar
Originally Posted by live2ride
Then again, is awesome still used?
You're bringin' it back!
Old Sep 25, 2007 | 07:23 PM
Nacho SS's Avatar
Nacho, thanks for the clarification in modern butchery of the English language.
As to my hearing the use of these while out in public, no. Then again the people I’m out with must have a much broader vocabulary and don’t mask profanity in cute little acronyms. If the occasion arises for it, they just let it fly so the intended recipient understands the message clearly. I also don’t waste what little free time I have chatting online. When needed I do use and recognize the simple ones to express emotion such as LOL and OMG which I assume means Oh My God. Why F***ing is inserted into everything is beyond me. Again I would point to a limited vocabulary where other non-profane words of expression can’t be readily accessed or understood by the audience. In the case of OMFG, I see no point in using that in a conversation with anyone. I also have little time for games but from what I’ve seen Halo is awesome! Then again, is awesome still used?
No problem...the butchery of the English language is so rampant these days internet slang butchery doesn't even matter .
Old Oct 3, 2007 | 08:49 AM
Taz34SS's Avatar
I shouldve have a .hpt file for you guys to try out later tonight.
Old Oct 3, 2007 | 09:30 AM
scarlett's Avatar
Can you list what you made for changes?
Old Oct 3, 2007 | 09:35 AM
Taz34SS's Avatar
yeah, tonight I will. So far I changed the shift points and how firm they are. Also, removed the gov, took some out of the TQ managment from the engine and tranny, disabled the codes needed for the high flow cat and fan settings.
Im still working and I havnt slept in a few days.
Old Oct 3, 2007 | 10:21 AM
Area47's Avatar
thats a good start
Old Oct 3, 2007 | 11:28 AM
Taz34SS's Avatar
Yeah, but I could use some help from ya... let me know if you have time tonight or not.
Old Oct 3, 2007 | 01:04 PM
Area47's Avatar
you can send me the file you're working on, and i can look over it.
Old Oct 3, 2007 | 03:59 PM
Taz34SS's Avatar
Sure, what is your email address?
Old Oct 3, 2007 | 04:35 PM
Area47's Avatar
pm me. i don't post it publicly
Old Oct 4, 2007 | 09:45 PM
Corny40's Avatar
Isn't there a way to get an HP tune onto a Diablo???
Old Oct 4, 2007 | 10:01 PM
  #32
06MonteSS's Avatar
LS1Tech Sponsor
yup...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Oct 4, 2007 | 11:35 PM
  #33
Nacho SS's Avatar
Taz-
I read/skimmed/ran through your tunes and log, make sure you get the Torque Management dialed out, and there's some tuning to be done in the fuel trim/power enrichment area. Also, log TPS (throttle position sensor, I didn't see it?) so you can tune for maximum performance when then throttle is open. AFAIK, the highest I've seen a ls4 throttle body open is 90%.
Old Oct 5, 2007 | 09:41 AM
  #34
scarlett's Avatar
Where the hell you do that Nacho?
Old Oct 5, 2007 | 10:09 AM
  #35
Area47's Avatar
crank the piston protection, and turn off the cat over temp. use the smoothing tool on the timing tables. this will reduce the chance of knock. remember, baby steps here, nothing big unless you know exactly what you're doing.
Old Oct 5, 2007 | 10:46 AM
  #36
hexxLS4's Avatar
Originally Posted by 06MonteSS
yup...
Is this documented anywhere?
Old Oct 5, 2007 | 08:08 PM
  #37
scarlett's Avatar
It's mentioned in Diablo's forum! BUT you lose your stock tune cause it replaced the HP Tune with the stock one. So you better save your stock tune some where first.
Old Oct 5, 2007 | 08:41 PM
  #38
06MonteSS's Avatar
LS1Tech Sponsor
correct...
be sure to save your current, real stock/OEM original backup to your PC first..
then you have to restore your original tune to your car, so the predator is unlocked and like new.
once your predator is unlocked and like new, and the HP Tune is in your car, you can hook it up and go to install a diablo tune.. it'll backup the HP Tune as your original backup, then install the diablo tune.
OR
if your predator is already still locked to your car and the HP Tune is in your car, you can go into Custom Tune > Read Extra Tune
the "Extra Tune" is whatever tune is currently in your car.
then you can go to your PC and go to Custom Tune > Export Tune > Export Extra Tune... start that, fire up the GMLS2InterfaceInstaller app, click the "get file" button, give the file a name and pick it's location to save to, then it will save that "extra tune" to your PC.
then to use it, you would just import it back into the predator as a custom tune.
__________________
Old Oct 6, 2007 | 12:15 AM
  #39
Nacho SS's Avatar
correct...
OR
Sounds easier to get HPT...
Old Oct 6, 2007 | 10:40 PM
  #40
Taz34SS's Avatar
Ok, so I have some stuff done, but I am still looking for a good way for 3-1 and 4-2 shifts, Full Throttle Speed and where to set the RPM Full Throttle Shift. Also, what would you guys say about setting the TQ management? Here is the file I am working on.
NM, cant upload a 2.2mb file on here. Can I send it to you Nacho or Area?
