Is it just me, or does the torque converter suck?
I had a Dynotech race tranny in my GTP before and after almost a year of driving the GXP I can't handle the trans anymore. I think the breaking point for me was having Kevin's car from Cartuning for the past day, he has a 2005 V6 GT with stock torque converter and oh my what a HUGE difference it is to drive it. When you let off the brakes the car actually starts to roll forward and I need very little throttle to get the car moving.
Anyone else experience this?
Get better tires and enjoy the extra power put out due to the higher stall which is the main reason these do such nice burn outs even when stock. Put a lower stall in and you will be in a lower part of the TQ band. Drive a stick in 1st or 2nd at say 1800 - 2000 RPM, then mash the gas. There is your low stall solution. If you have sticky tires and a TQ converter that puts you in a good solid part of the TQ curve you will launch hard.
I think a converter that stalled in the 2500 RPM range would have been a better compromise to the one they put in, but I'll take the extra stall for the fun of it.
I can certainly tell you that if these cars had a 12" diameter converter you would have immediate take-off and be roasting the tires with next to nothing for throttle.
So when you say STR ratio, what specifically in the trans is creating this other than the first gear raito of 2.92 which is almost identical in ratio to a 4L60E transmission which uses a 3.06 first gear ratio which means for all intent and purposes the only difference in take off between our cars and an LS1 Z28/Trans Am with the 4L60E trans is the converter?
O6 SS...not trying to pick on you.....just trying to get educated!
Now, maximum torque multiplication takes place when the engine speed is as much higher than the output of the transmission (read: at a stop). For example we can use my '95 LT1 Caprice. 3.73 gears+2800 stall+~350 lb-ft+~2.45 STR means it is hard not to melt the 255 tires when leaving a stop sign. Goes like this: Hammer the gas, stalls up to 2800, say it makes 320lb-ft of torque here. The STR multiplies this by 2.45ish and the tires see the equivalant of almost 800 lb-ft of torque for a moment. (as the speed of the output gets closer to the input, the STR ratio drops closer to 1:1 until they are equal when the input speed = output speed.
Same scenerio with the (questimated) 2800 stall and 1.8 STR of the LS4. At 2800 the little 8 makes ~290 torque. Multiply that by 1.8 and you get momentary torque at the tires of 525 lb-ft. The tires are much less likely to go up in smoke with an agressive launch that uses all of your stall (and using that stall gets you in the powerband faster). Downside is that, the car feels lazy as it takes more throttle to get the same output down low until the speed of the trans output gets closer to the speed of the engine/trans input. My high STR LT1 will creep forward when you take your foot off the brake and it probably has the same stall as the LS4.
Generally, low STR, high stall is good for drag racing because you get into your powerband quickly and can get good traction at the launch because of the lower torque at the rear of the tranny. (rubber tires have a greater static coefficient of friction than dynamic, meaning they grip harder when rolling than when stopped)
Higher STR will make the car feel stronger and have better low end response.
Probably made it worse with the explanation and I might have to go back and edit it a time or two after I reread it and see if I reversed anything.
Every modification I have seen for an automatic trans for better launch qualities focus on the gear ratio and torque converter. Where can I find more specific information on your theory? I've reviewed websites for auto trans modifications and didn't see any mention of modifying the components you mention for better launch....these two sites offer complete trick modified 4T65-E transmissions....why don't they mention STR or what components to buy to change this ratio? http://www.transmissioncenter.net/alto_2.htm & http://www.intense-racing.com/Mercha...ategory_Code=T
Again, I'm not trying to be a hard *** about this ...I'm just trying to learn!
