MCSS Swaybar Size
I'm going to poly my front and rear bars and endlinks ... do any of you guys have a micrometer to get a definitive answer?
Thanks!
On the Impala, which runs the same setup, it's 34mm and 18mm. ***k what GMCanada says...they apparantly can't measure even in metrics. (their site claims 19.4mm or something like that).
No, i have not measured anything, but i'm 95% certain those are the correct sizes.
got this off motor trend.com
Monty...pretty sure that's incorrect info as well. The 19.4mm hollow rear came from GMCanada's specs, which, i believe, someone disproved. The US figure was 18mm & solid. My OEM bar was 34mm and solid, as is identical in part number to the solid GMPP front sway available in the performance handling package from GMPerformanceParts.
EDIT: At http://www.chevrolet.com/impala/features/
SS models and — NEW for 2008 — LTZ models feature more aggressive spring rates, a larger 34mm front stabilizer bar and 18mm solid rear stabilizer bar. This suspension is tuned for crisp handling using the 18-inch W-speed–rated Performance tires.
When I "shake" my car at 75, the *** wags, waiting for it to get above freezing to get underneath and see if an end link or something is broke. Tire PSI is at 35 hot right now, usually I keep it at 38 in the summer.
I'll order the poly mounts and hopefully get them on the car before the new year, then try out the new found handling on the ice!
