Throttle Body Spacer
Perhaps this is why that dude with the Silver MCSS is going almost 108mph traps too after having the intake pro ported?? Its just too much work and mickey mousing to convert this intake over to a normal one...
If it does do that and you port it out to match the throttle body, it will lose the grooves and not spin the air anymore, thus making it pointless. Am i correct in this thinking? O and by the way the grooves on mine are pretty big.
What did you see for #'s then if you saw actual gains on the dyno??? Im certain the increase in plenum volume is what would gain the power, not some twirly marketing gimmic.
thx man...
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
give me a break lol youd have to be stupid to pay 200 bucks for which basicly is a giant over rated spacer.
What makes more sence having a shorter air intake or a longer air intake. When you add a "tb spacer" your just adding length to your intake how is this going to increase HP. The original idea was for carbed engiens to allow the fuel and air to mix together before it entered the cylinder. Our cars are fuel injected so there is no fuel mixing before it enters the cylinder. If you need a tb spacer to help your fuel "atomize" then you need to install new injectors.
Would you still have fitting problems if you didn't have a K&N but stil a CAI that didn't change anything beyoud the MAF?
