Finally got the wheels on!
And my awesome helper
The fenders DO need to be rolled, so I'll get to that, but it doen't seem like an emergency...but I will still push to do it soon. The ride is excellent....much better than my winter tires in both the noise category and balance (must have lost some weights on the winter tires).
R1concepts w/Hawk pads are in the works as well, and now that I can SEE the ugly calipers I will paint those as soon as I can (probably tomorrow evening so they can sit overnight).
Only problems I ran into were 1. the hubcentric rings they gave me did not fit the wheel. They went on the hub nicely, but were too thick for the wheel. and 2. there is very little room around the lugs, so both the cross-wrench and impact wrench scrubbed a bit while tightening...so I'll need to touch that up to prevent rust (it's beneath the center cap).
I must say, I did well, if I don't say so myself :wink:
What are you gonna use to paint the calipers?
I need to find some money to be able to do the Eibach kit. The brakes will cost me between $350 & $450, and another $250 for the springs (plus install, if I can't DIMyself). That doesn't factor in the cost for the fender rolling (if I EVER find someone to do it). Going to call a couple body shops today and tomorrow.
I have the Duplicolor Silver caliper paint kit at home, so if the weather holds true tonight, I'll try to get that done.
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Here's a quick pic of the car after having been driven a bit. ALthough the heavy *** jack is still in the trunk, it's settled a bit and doesn't look as high after all:
Still have plans to lower it, though. Anyone know of a decent write up for replacing springs?
While he's got a pretty plain garage with an '03 Imp LS and a Chevy conversion van, he's had his fair share of hot cars in the past, including a few '60's Impalas.Just happened to catch it at sunset. It wasn't where I normally parked at the park (if you noticed before, most of my pics (sig included) are taken at the same park off Lake Erie), but I couldn't afford to lose that opportunity to get the sunset in there. As much as I like to be semi-original with photos, I also like to be able to show the transformation of the car from totally stock to where it is now. I'll have to post a collage someday of the car in its different stages.
The car is looking like a champ!
I think the 255 tires is what caused the rub.
When you get to the calipers, clean out that wheelwell and spray a little tire shine up in there.
Keep up the good mods
Yeah, Corny40 said from the beginning that the 255's were the cause...so I was expecting it. Now, I just need to fix it before I ruin something.
And yeah, I NEED to scrub the hell out of the fender linings...it's nasty after the winter. Not sure when I'll be getting the rotors, but I will be cleaning the fenderwells soon.
