Adding Tap Shift and remote start, can it be done?
Old Apr 7, 2008 | 11:32 AM
LS4 swap's Avatar
Question Adding Tap Shift and remote start, can it be done?
I am going to do an LS4 drive train and wire harness conversion into my 88 Fiero but my 06 Montecarlo SS did not have the Tap Shift or remote start from the factory. Can I add the two functions to the swap using factory stuff? I don't want to use after market add ons.
So basically this would be the same exact process as adding Tap Shift and remote start to a stock LS4 car.
Old Apr 7, 2008 | 11:54 AM
06MonteSS's Avatar
LS1Tech Sponsor
GXP is the only LS4 that had the tap-shift setup... monte's and impala's did not... so see if you can find the necessary stuff from a GXP to do that... the wiring harness, the steering wheel, any necessary tranny controls for the tapshift stuff, etc etc...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Apr 7, 2008 | 01:28 PM
LS4 swap's Avatar
Thanks.
Old Apr 7, 2008 | 07:47 PM
TiredGXP's Avatar
You want to double check with Ryan over on PFF. He tells me that he wired the paddle shifters on BLKCOFY's LS4 swap directly to the TCM. It will definately depend on the operating system loaded into the TCM.
Just FYI, if you know the VIN of the donor car, you can go here to get the O/S: http://tis2web.service.gm.com/tis2web
I'm sure GM could tell you if that O/S supports Tapshift.
The "calibration details" screen in HPT also records the ECM and TCM operating systems. For the 2005 GP GXP I have TCM O/S: 24235742
**Edit - remote start is another function controlled through the BCM. If you don't have one, or if the one you have didn't support remote start, then you are going to have to look at an aftermarket unit**
Old Apr 12, 2008 | 11:55 AM
ls4fiero's Avatar
Default tap shift conversion.
This issue was discussed on the Fiero forum. I have the 06 gxp manuals and they show some different valves in the tap shift trans. The tcm also has a different number. (don't know what that means) The paddles are just switches that switch different resistor values on a single line to the tcm. I think that the hard parts in the trans will be the big issue.
Good Luck
Old Apr 12, 2008 | 01:26 PM
ctsls6's Avatar
tci have paddles that with work for any 4l60e its 500.00 give them a call. i was going to do it on my 2000 z-28.
Old Apr 13, 2008 | 10:22 AM
hexxLS4's Avatar
Anyone know if it would be possible to mod a monte carlo to have tap shift?
