Impala SS Flipped motor mount..... ? ? ?
Old Apr 25, 2008 | 09:47 AM
2006ImpalaSS's Avatar
Default Impala SS Flipped motor mount..... ? ? ?
What is the deal with this? Can someone explain? Please.
Thanks
Old Apr 25, 2008 | 10:32 AM
20SS07's Avatar
From another thread...
Originally Posted by BADDLS1SS
I also just completed the motor mount flip too about 10 min ago. Wow what a diff! Now even more wheel spin! Bwhahahaahahahah Throttle responce is just brutal!
I suggest doing this mod if you havent already. All you do is rotate that top square motor mount in its braket to so when the motor pulls on the mount it pulls on the solid rubber portion instead of the open windows of the mount like in the stock posistion which allows like a 1/2" of flex.
The two arrows point tothe two mount bolts that need to come out completley. Then once the dog bone is out of the way take one bolt and nut and tighten it inside of that rubber mount thats in the bracket on the red radiator support and tighten it well!
Now spray some WD 40 around the whole diameter and both sides of the that rubber bushing on the bracket still on the car then take your ratchet and 15mm wrench and rotate both at the same ttime twoards the engine till that mount spins inside the bracket and the solid rubber section is facing front and rear and the open windows up and down. Reassemble and test it out.
Old Apr 25, 2008 | 03:07 PM
Taz34SS's Avatar
Looking at that pic really makes me want my rockers installed BAD...
Old May 10, 2008 | 12:52 PM
CardinalsRed's Avatar
what kind of rockers are those? can you tell a difference in power? how much did they cost?
Old May 10, 2008 | 01:42 PM
lovemyls4's Avatar
