Flipped Motor Mount, Bracket won't line up HELP!!! Flipped my motor mount and can't get the beacket back on. It will not line up at all. Pushing the car backwards has done squat. I have to get this back on, any responses would be appreciated. |
motor shouldn't have moved THAT much... push on the engine mount where the bracket goes... got a pic you can post??? how far off is it?? what's not lining up?? |
Originally Posted by 06MonteSS
(Post 9355233)
try flipping the dog bone over... make sure you don't tighten up either end until you have both bolts through, so you can still move the dog bone to get it line up on both ends.. |
I got it, thanks guys. I didn't realize how much strength it would take. Giving it some good power I was able to flex the mount enough to jam the bolt through. Now hopefully a test drive soon. |
Put the bolt facing the front first do not tighten it, try using a good screw driver by putting it through the mount on the motor and partly through the dog bone and apply pressure to get them to line up with your other hand stick the bolt on the other side. hope this makes sense. I had to do this since my motor mount was pretty baked as I did this at about 18K miles. |
I had the same problem when I did the flip after getting rid of the poly mount. I had my daughter rev the engine while I tried to get it back in. That worked. |
Or you could put the car in neutral and set the E-brake and the engine moves very easy then. Tate |
Originally Posted by Compg
(Post 9363406)
Or you could put the car in neutral and set the E-brake and the engine moves very easy then. Tate OH do I miss that car. :( |
i would like to do this simple mod does anyone have pics of a write up, i grasp the concept but i need pics to do it |
There are a few threads with the photo you need. Scroll through the first couple pages in LS4 section and you;ll likely come across it. |
| All times are GMT -5. The time now is 12:59 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
