steering column clunking...my turn with this headache
Old May 15, 2008 | 03:21 PM
importandy's Avatar
Default steering column clunking...my turn with this headache
Just wondering if it starts out as mild clicking as the car flexes on take off and stopping?? I noticed mine is starting to click./
Old May 15, 2008 | 04:45 PM
98Jeep360Limited's Avatar
Sounds like the ISS. The dealer will either lube yours or replace it, then it should be fine.
Old May 15, 2008 | 06:58 PM
Nacho SS's Avatar
Tell the dealer to replace the damn thing.....
Old May 15, 2008 | 08:34 PM
Taz34SS's Avatar
I Really thought they had the ISS issues fixed from 04-up... GUess now. When are they going to learn and fix that ******* issue. ??????
Old May 15, 2008 | 10:53 PM
LS4 swap's Avatar
What exactly is the ISS issue?
Old May 15, 2008 | 11:07 PM
Morpheus's Avatar
Steering shaft. Happens to most GPs and Lacrosses that I've seen. It's also common on the old body Tahoes/Yukons.
Old May 16, 2008 | 07:34 AM
Taz34SS's Avatar
The ISS can not handle the weight of the W-body and starts to wear away. It will start to dry up and then you will hear a noise and feel something from the steering wheel when you turn it. MOst dealers would just re lube it untill 2003, when they did come out with a replacement part. I guess now they have the same problem.
Old May 16, 2008 | 03:21 PM
importandy's Avatar
Well my car is an 08 with 4000 miles. WTF
Old May 16, 2008 | 04:52 PM
Taz34SS's Avatar
My car is an 07, with only 3930 total miles on it and I do not have this issue at this time. Neither does my wifes 06 Impala SS
Old May 16, 2008 | 06:00 PM
Sint3k's Avatar
I didn't have mine until around 15k and i never got it fixed until 23k when it got alot worse.
Went from poping every now n again and then 7k later it poped every turn i made at low speeds.
