Monte Carlo door speakers
Old Jun 8, 2008 | 02:37 PM
supercatxr7's Avatar
Default Monte Carlo door speakers
I have an 06 SS and just replaced the rear 6x9's, sounds better for sure. I have a set of 6.5" for the doors, but have not put them in yet. I have the stock basic 4 speaker system.
I was told I need an adapter to put in aftermarket 6.5" in the doors due to the fact that the stock tweeters are run seperate? Is this correct or only for the 8 speaker set up?
Thanks,
Old Jun 8, 2008 | 06:56 PM
CardinalsRed's Avatar
you shouldn't need an adapter. you would just replace the speakers and not the tweeters but i'm not too familiar with audio
do your 6x9s make more bass? what speakers did you get for front and rear deck?
Old Jun 8, 2008 | 08:44 PM
Sint3k's Avatar
Thanks,
The tweeters are only seperate if you have the 8 speaker system. in the 4 system the tweeter is in the center of the bass cone. no adapter.
to be sure you don't have the 8 speaker system check in your trunk under the rear deck and see if you have a small amp
Old Jun 8, 2008 | 09:02 PM
They're Sony speakers, rears definitely sound better now. Thanks for the info, now I can change the front.
Old Jun 8, 2008 | 09:06 PM
Corny40's Avatar
Let us know how it goes.
Old Jun 10, 2008 | 04:16 PM
so does the new 6x9s make more bass? the stock ones do okay but i wanna take my audio system to the next level
Old Jun 10, 2008 | 04:19 PM
Nacho SS's Avatar
Want bass? Get a sub.
Old Jun 12, 2008 | 11:14 AM
ya i've been thinkin about that but i don't want a box in my trunk. i'd want to get it custom done in the rear deck
Old Jun 12, 2008 | 02:36 PM
Sint3k's Avatar
there is a 32 by 10 inch space in the back of your trunk that is most likley being unused and is pefect for a 12 or 2. in a sealed box.
Old Jun 14, 2008 | 12:26 PM
good call. in front of the wheel well?
Old Jun 14, 2008 | 12:37 PM
neilownz's Avatar
Who needs a spare tire anyways. Just call roadside if you get a flat.
Old Jun 14, 2008 | 04:56 PM
Nacho SS's Avatar
Subs don't go in the spare tire location...
Old Jun 14, 2008 | 07:17 PM
Sint3k's Avatar
My box is so big it covers it and is extremly difficult to get to it plus u can easily use the spare tire area as a enclosure for a small sub very usefull :X
