GXP Transmission Fluid Temps
Old Aug 12, 2008 | 08:12 PM
Bort44's Avatar
Default GXP Transmission Fluid Temps
Hey guys, I gotta 08 GXP. My transmission temps are around 175 to 180 degrees. Is this to high. What can I do to lower them. Any help would be great. Thanks.
Old Aug 12, 2008 | 10:28 PM
mp4life23's Avatar
No thats not to high i would say thats a little low. Usaully on a long drive on a hot day 90+ mine hovers around 205 -210 i wouldnt worry about that
i think most of us would agree thats a good temp.
Old Aug 12, 2008 | 10:46 PM
scarlett's Avatar
83c under normal driving and then shoots to 103c if i am smacking it hard
Old Aug 13, 2008 | 12:59 AM
MonteSS8707's Avatar
I've always been told you typically want your tranny to run 10-20 degrees cooler than your engine for optimal performance and longevity. I think you'll be just fine.
Old Aug 13, 2008 | 01:14 AM
Pauls325's Avatar
Mine seems to be running hot lately around 200 in 70 degree weather when i was autocrossing i hit 230 before that i had never seen it above 212 hope i didnt bust anything
Old Aug 13, 2008 | 06:28 AM
Bort44's Avatar
Thanks guys for the info.
Old Aug 14, 2008 | 03:25 AM
StealthV8's Avatar
i hit 225 before and my trans has 50000 miles on it
Old Sep 10, 2008 | 08:29 PM
Pauls325's Avatar
so i called gm about operating temp in our transmissions the guy told me normal operating temp is up to 230 he said you should worry if you hit 260 so i think these things can handle a lot of heat
 Michael S. Palmer
Old Sep 10, 2008 | 11:07 PM
Nacho SS's Avatar
Get aluminum heat sink tranny pan and a tranny temp gauge if you're that worried.
Old Sep 11, 2008 | 07:21 PM
08GXP's Avatar
I'd have to install a trans cooler to keep it under 185 degrees! I don't know how you drive your 08' GXP, but even when I think I'm babying my 08', my tranny runs about 190 degrees. Consider yourself lucky. I've had mine up to 240 degrees before (using Tapshift and spanking high dollar, foreign cars light after light = FUN!).
Old Jul 25, 2013 | 09:57 AM
centergod79's Avatar
hello
Old Jul 26, 2013 | 08:39 AM
blkchevyz's Avatar
probably not what you want to hear but mine seems to run cool like that right before it went to ****.
Old Jul 26, 2013 | 02:45 PM
LS1 Racing's Avatar
Nice. This thread is almost old enough to drink.
Old Jul 26, 2013 | 06:39 PM
D J Real's Avatar
I had to come out of retirement to at that,
Guys anything above 200 is bad news, the highest I'd ever push a stock 4T65E-HD is 185ish before i'd freak out. There is a reason this transmission is under investigation for a recall and heat is it. Its cooled poorly through the radiator stock and if you run stock trans parts on this car sooner or later it will fail. That is documented fact not an opinion.
If you guys want more info read the sticky on the top of this sub forum or go to gmsl4.com, really good conversations about this trans on there.
O.K. back to lurking...
Old Jul 29, 2013 | 10:41 AM
Dom87SS's Avatar
Mine sits at 185-205 normally but gets up to 210-220 when on the highway or stuck in traffic.
