gas tank shield
Old Sep 13, 2008 | 08:09 PM
jgardner9@stny.rr.co's Avatar
Default gas tank shield
How well can the gas tank hold up to the heat from the exhaust pipe heat. I have a Magnaflow exhaust and right before the Y-split it is about a half inch away from the gas tank. The spot I am talking about is in the right rear of the gas tank. The OEM shielding stops short of there since it was routed a little different. Should I put something in between the plastic gas tank and exhaust pipe? Anybody else notice this?
Thanks in advance,
_____________________________
Jeff
2008 Dark Gray Grand Prix GXP
Magnaflow Exhaust
Old Sep 13, 2008 | 11:27 PM
Pauls325's Avatar
well when i just had a thrush turbo bolted on after the o2 sensor my exhaust was getting shot right into it for probably a week i had it like that i had no problems
Old Sep 14, 2008 | 11:27 AM
Nacho SS's Avatar
I think the tank is double walled.
Old Sep 14, 2008 | 05:04 PM
BuffaloSS's Avatar
I've had the MF exhaust for quite some time with no issues back there. You're probably fine leavin it alone.
