Powered subwoofer power cable
Old Oct 1, 2008 | 08:57 PM
jgardner9@stny.rr.co's Avatar
Default Powered subwoofer power cable
Where would be the best place to attach the 10 AWG power cable to near the battery?
Thanks for your help,
Old Oct 2, 2008 | 10:52 AM
BuffaloSS's Avatar
You talking about the amp turn-on cable, or the amp power cable? The former tells the amp to turn on, while the other just supplies the power.
If you're already looking near the battery, I'm assuming that you're talking about the power wire. You should just crimp a ring to the end of the cable and put it right under the nut on the battery post, or the power post @ the fuse block. Make sure that you have a properly rated inline fuse close to wherever you connect.
EDIT: and this probably could have been added to your original post about running this wire
Old Oct 2, 2008 | 10:55 AM
20SS07's Avatar
I used the power post @ the fuse block.
Old Oct 2, 2008 | 11:36 AM
Sorry I was referring to the power cable. Thanks for the reply!
I plan on running it thru the grommet on passenger side fire wall along the door sill to the trunk.
Any problem of running 2 items (GPS, Radar detector) off of the TAP wire (going to pwr window) in right front passenger area?
Old Oct 2, 2008 | 01:04 PM
Sint3k's Avatar
both are very low amp devices i doubt you'll have a problem you'll know quickly when the fuse blows no big deal. as for running 10 gauge power cable ? don't you think you should run at least 4 2 or 0 gauge ?
