LT1 Backfire after round of Mods. HELP
It seems like heat plays a role in when it backfires. I can have it idle for 3-4 minutes and no issues, but then it will start to backfire, more and more as it runs (gets warmer).
http://shbox.com/1/4th_gen_tech2.html#adjust_valves
this method is pretty universal whether it be hydraulic or hydraulic roller
Here's a better link for him
http://shbox.com/1/4th_gen_tech2.html#poly_locks
Im wondering if its not electrical since it seems to start backfiring as the car warms up. I noticed last night that the headlights are on when the key is on, and the switch is off. I also have the right blicker light on (not flashing) the dash on when the key is on and blinker off. In addition the blinker light is on (not flashing) when I turn the lights on without the key on. Bad ground perhaps? I did have the battery relocated during the mods so that could be it.
Im gonna connect a jumper cable to the battery and the other end to the block just to double check.
Sadly, you can't exactly pin-point which one it is and you'll have to do them all :S
