how can I run 10's?
Old Sep 12, 2003 | 07:28 PM
kevsbird's Avatar
Default how can I run 10's?
I have a 94 forumla with a MTI heads, a cc306 cam, hooker long tubes, mufflex 4 inch,tnt set@150, 28x10.5 et drags, M6, 9 inch with 4.10's. Will it go 10's, or not?
Old Sep 12, 2003 | 07:51 PM
chevyguy3's Avatar
Default Re: how can I run 10's?
should go 10s pretty easy on the 150 shot
what happened on the 11.56 @ 110 pass? that doesnt work out right
Old Sep 13, 2003 | 05:59 PM
kevsbird's Avatar
I ran out of rpm. had to go into neutral.I really want to go 10's on a stock short block. Is this feasable?
Old Sep 13, 2003 | 06:49 PM
I8AFORD's Avatar
Why did you run out of RPM..cause the 28s should make the 4.10s like a 3.8xs
I would think that would be about perfect for H,C,I and the spray
I would think that N/A U could run a 4.56 on that tire
tell us more please,what gear where you in at the traps and RPM?
Old Sep 13, 2003 | 07:37 PM
RacinLT1's Avatar
well,im running 11.022@124 with a stock LONGBLOCK.
so 10's on the stock shortblock should not be an issue. many guys have gone with 10's with heads/cam/power adder.
im not sure how many guys have gone 10's with a stock longblock,but im sure as heck gonna be 1 of em.
Old Sep 14, 2003 | 03:05 PM
kevsbird's Avatar
The 28's are a new purchase. The times were on 26x11.5x16 et streets. 4th gear, shifting some where near 6200. Gonna try for tens at Bowling green on the 20th. The cage is done, so I should be legal
