infamous Intake manifold leak
Old Oct 13, 2008 | 09:36 PM
Pretyflywiteguy's Avatar
Default infamous Intake manifold leak
Those are just about all the emotions I felt today while dealing with this damn car..
I figured it would be about a 4 hour job tops and it has now turned into 2-3 day job because I always end up breaking ****.
First off:
I broke a the hose that goes from the TB to the passenger side valve cover, it has a little bit of oil in it.. What is it called? Where can I get a replacement? Is oil bad?
Second:
I broke the EVAP canister purge solenoid valve hose that connects to the EVAP canister. Where do I get a replacement? I broke it right next the TB.
Old Oct 13, 2008 | 10:58 PM
kinglt-1's Avatar
the oil is normal, your pcv system vents into the throttle body. The local autoparts store should have both hoses.
or here www.gmpartsdirect.com
Old Oct 13, 2008 | 11:49 PM
I tried the local places no one has it..
also, i don't think this is normal. blow by?
(some intake ports are black and others are clean)
motor runs fine no knocks or anything, still pulls hard.
Old Oct 14, 2008 | 04:14 AM
SS RRR's Avatar
Village Troll
Man that is nasty. Already replied to your thread at CZ28.com.
